Farmall Tractors Discussion Board
Re: stuck sleeves
Posted by Dennis on April 07, 1999 at 08:56:00:
In Reply to: stuck sleeves posted by jim on April 06, 1999 at 13:58:52:
I had a plug made to fit sleeves with a center hole in it at a machine shop. $30 then I ran threaded rod up to a flat bar and used two hydraulic jacks to jack the sleeves out. you can also jack the new ones in. worked well
Post a Followup
: Re: Re: stuck sleeves
