Farmall Tractors Discussion Board
Re: starting 656
Posted by JK MN on April 07, 1999 at 12:47:02:
In Reply to: starting 656 posted by Don on April 06, 1999 at 20:46:41:
Don, On the upper side of the Rosa-Master pump is a small bleeder for the pump case. Clean the area around it an open it until fuel flows from it. Close it and do the cranking with the injector line(s) loosened. Also how much fuel did you put in the tank? Put enough in for a better gravity head of pressure. Good luck.
Post a Followup
: Re: Re: starting 656
