Farmall Tractors Discussion Board
Re: Non foul plugs
Posted by Farmall Gray on April 07, 1999 at 18:58:37:
In Reply to: Non foul plugs posted by RED Blooded on spark plugs on April 07, 1999 at 17:05:53:
If they are the ones I'm thinking of they take
a lot of ignition current to fire because of the wide gap. I have a
snowmobile that uses them as original equip.
It has CDI ignition. They still foul if if I dont
have the carb set right or the fuel is mixed too
rich. They can be cleaned and reused though. Just spray them with carb cleaner and wipe them off with a rag. I don't think they would be any advantage in a tractor unless you have a hotter
than stock ignition system.
Post a Followup
: Re: Re: Non foul plugs
