Re: 3 point conversion
Posted by Ksfarmmer on March 18, 2009 at 08:00:12 from (68.103.17.55):
In Reply to: 3 point conversion posted by darylh on March 17, 2009 at 20:18:49:
That is a common problem with the 2pt to 3 pt conversion. Some of the tongs have an upward bend that allow you to lift implements a little bit higher. My experience with the converters is that they work marginal at best. The single piece converter that has prongs attached to a U-shaped frame that connects to the 3 points of the implement seem to work the best, but are expensive, if you are even able to find one. Don't believe they are made anymore. I don't know what option you have other than to modify prongs or the digger.
