Farmall Tractors Discussion Board
Re: Oil Type
Posted by Farmall Gray on April 09, 1999 at 16:22:54:
In Reply to: Oil Type posted by Paul V. on April 08, 1999 at 21:13:13:
Make sure you use oil that is rated for diesel use
if you tractor is a diesel. I believe a TD-40 is a deisel, right? 15W40 is the most popular weight
of deisel oil. SAE 30 is also popular, but you should probably use multi-grade in winter.
Post a Followup
: Re: Re: Oil Type
