Farmall Tractors Discussion Board
Re: farmall md
Posted by Ronnie on April 09, 1999 at 19:31:13:
In Reply to: farmall md posted by nathan hoffman on April 09, 1999 at 09:02:58:
Four bolts removes the tricyle front. You will need an after market front or a factory front off a M or MD with the steering arms out in front. You will have to drill holes in the frame of your MD to get fronts off Super M's to 450's to work. Fronts off 560 and newer will set the front end of your tractor up about three inches above level. After market fronts will cost about 300. to 600. dollars depend on condition.
Post a Followup
: Re: Re: farmall md
