Farmall Tractors Discussion Board
Re: Farmall regular clutch
Posted by C.Fitz on April 11, 1999 at 03:49:26:
In Reply to: Farmall regular clutch posted by jeff on April 10, 1999 at 05:21:59:
You should see 6 bolts around the outer edge of your clutch plate. Take every other one out; leaving 3 still holding your clutch plate on. On your clutch plate you should see 3 half-inch holes with no bolts in them. The 3 bolts that you have already removed go in here and tighten them up ; as you are doing this you should see your clutch springs re-tracting. Keep tightening until all 3 clutch spring fingers are fully retracted. Now all you have to do is un-bolt the remaining 3 bolts along the edge and your clutch will come right out. Good luck.
Post a Followup
: Re: Re: Farmall regular clutch
