Farmall Tractors Discussion Board
Re: Super A with no spark - mag
Posted by Farmall Gray on April 11, 1999 at 14:47:39:
In Reply to: Super A with no spark - mag posted by Bob A on April 11, 1999 at 10:36:32:
Are you sure you have a mag and not a distibutor?
A mag makes it's own current and does not need power from the battery. A mag only has 1 wire that runs to the ignition switch which just grounds it out. If the mag is working correctly,
it will make spark without the wire hooked up. If you ran current from the battery to the coil of a mag, you probably burned out the coil. Find someone who knows the difference between a mag and a distibutor before you go further.
Post a Followup
: Re: Re: Super A with no spark - mag
