Farmall Tractors Discussion Board
Re: Re: ATTENTION: all you 6V - 12V converters
Posted by RK Smith on April 11, 1999 at 20:06:38:
In Reply to: Re: ATTENTION: all you 6V - 12V converters posted by Ralph on April 11, 1999 at 19:13:13:
didn't say anything about a chrysler alt, just the referenced volt reg. Just happens to work well in the system. I'm sure one could be found from GM, or Ford that would work as well, and I'm sure an alt made by other than Delco Remy would also. Mine happened to be a Delco Remy and on the tractor when I bought it, and the owner said he had just converted it to 12V with an alternator. He had it hooked up wrong in the first place, and secondly it was "not internally regulated," so the volt reg was required. It was recommended to me to try a "chrysler product pre-70 voltage regulator. This one happens to be very compact, easy to install, and two-wire simple.
Post a Followup
: Re: Re: Re: ATTENTION: all you 6V - 12V converters
