Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: how do you.....
Posted by Phil Auten on April 13, 1999 at 05:38:23:
In Reply to: Re: Re: Re: Re: how do you..... posted by Tom from Ontario on April 12, 1999 at 19:13:04:
Mark,
If you end up with an A or B, there are ways to add hydraulics such as switching to the engine from a C or Super C which has the hydraulic pump bolted to the side below the distributor/mag. There are pumps available to run off of the front engine pulley or the belt pulley and then you add an aftermarket 3-pt. hitch or build one yourself.
This is a lot of work, but if that's what you want, go for it!
Phil
P.S. There never was a Super B.
Post a Followup
: Re: Re: Re: Re: Re: Re: how do you.....
