Farmall Tractors Discussion Board
Re: how do you.....
Posted by John C. on April 13, 1999 at 06:51:27:
In Reply to: how do you..... posted by Scott Hansen on April 12, 1999 at 13:25:16:
Maybe I'm missing the point of the question, but before the hydraulic assist became standard on tractors, the drawbar-type moldboard plows had an eccentric mechanism in one of the wheel hubs. The driver pulled a cable which tripped the eccentric mechanism. The motion of the wheel then caused the eccentric to either lift the plowshares out of the ground, or drop them into the ground. There was also usually an adjusting lever on top of the plow that set the plowing depth in the "low" position. Some plows would only "lift" or "drop" when rolling forward, and some would also "lift" while rolling in reverse, making it easier to get out if you got bogged down. FYI...I own a B and I plan to add 3-point to it someday, but it looks like a lot of work.
Post a Followup
: Re: Re: how do you.....
