model a radiator
Posted by josh watson on March 18, 2009 at 17:26:51 from (69.21.16.57):
I recently replaced my coolant temp gauge. After running the tractor for at least 20 minutes , the gauge needle still hadent moved. When the A was shut off , i could hear the radiator bubbling away. Did i not wait long enough? also, after, I removed the temp bulb and the coolant that flowed out was cool.
