Re: 404 hydraulic lift
Posted by pete 23 on March 18, 2009 at 17:31:44 from (173.87.1.12):
In Reply to: 404 hydraulic lift posted by Bob 35 on March 18, 2009 at 16:24:37:
If you changed the fluid I will assume you changed the filter. Try holding the aux valve on demand while raising the hitch. If the speed of hitch changes you have a problem with the unloading valve inside the draft control valve assembly.
