Re: Preventive Maintenance
Posted by CNKS on March 18, 2009 at 17:35:57 from (216.144.104.128):
In Reply to: Preventive Maintenance posted by Dr. Bert on March 18, 2009 at 16:06:05:
No one will laugh, because yours is a common problem. Most or all of the bolts do not go through. I suppose it could work its way through the cover gasket. But, most of the water is either condensation or enters through the gearshift lever. Probably mostly condensation. IH recommended a fluid change once a year. Almost no one does that.
