Farmall Tractors Discussion Board
Re: Water pummp for a Farmall H model
Posted by justin on April 15, 1999 at 10:23:51:
In Reply to: Water pummp for a Farmall H model posted by Joey on April 15, 1999 at 10:03:15:
From my past experience, it is better to just remove the water pump, and reuild it.. this will probably cost $50.. in rebuilding the pump, you will replace the bearings, seals, packing, and bearing spacer.. i know this is a little more complicated than just adding new packing, but it is well worth the work over time.
Post a Followup
: Re: Re: Water pummp for a Farmall H model
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
