Farmall Tractors Discussion Board
Re: Re: Water pummp for a Farmall H model
Posted by justin on April 15, 1999 at 13:03:44:
In Reply to: Re: Water pummp for a Farmall H model posted by Joey on April 15, 1999 at 11:48:57:
joey,
All the parts needed can be obtained through your local IH dealer.. There is no need to order from a dealer where you will need to pay shipping.. the 290 dollars which they quoted you earlier is for a kit with the impeller.. usually the impeller is okay, but not always.. Here are the part numbers to call your dealer:
48025D Felt Washer
51492DA Oil seal (need 2)
ST225B Bearing (need 2)
48027D Bearing spacer
45925DA Packing (I usually get 3)
45091D Water pump mounting gasket
I can't remember if the bearing spacer is still a valid number or not,but if it is not, have the dealer run the number through dealer locator, or also advise them to check obsolte parts depot... Like I said in the earlier posting, all of these parts should only cost about $50.00 they may be a little bit more, but not much.. Hope this helps..
Post a Followup
: Re: Re: Re: Water pummp for a Farmall H model
