Re: H Power vs 140
Posted by Hugh MacKay on March 18, 2009 at 18:39:50 from (209.226.247.71):
In Reply to: Re: H Power vs 140 posted by randy hall on March 18, 2009 at 16:15:12:
Randy: Don't get too cocky, the H would be quite aware of the 140 presence. My brothers once hooked Farmall 130 drawbar to drawbasr with a 52 hp David Brown 990. Farmall 130 had wheel weights and chloride, the David Brown had neither solid or liquid weight added. It did have 16.9x30 tires. On hard gravel driveway the 130 pulled David Brown backwards wheels spinning and diff lock engaged. Guy on the 130 decided to give David Brown head start, however soon as he dropped his clutch everything went in 130 direction. It wasn't until they went to a feild situation that DB pulled 130 backwards.
Yes, the H will pull the 140 backwards, but don't get the idea it will be a run away. Your talking roughly 25% more hp and 25% more weight, that's all. Believe me, I farmed quite a few years with H, 300, 130 and a Cockshutt 540, and the 130 could make it up the grade to our barns pulling 150 bales of hay just as fast as any of the rest.
