Farmall Tractors Discussion Board
Re: Farmall H front Hydraulic Pump
Posted by john d. on April 16, 1999 at 06:43:30:
In Reply to: Farmall H front Hydraulic Pump posted by Randy from Missouri on April 15, 1999 at 17:50:00:
This "front pump" is a live-power pump. It is not controlled by the clutch, as the standard hydraulic system (lift-all) was on these tractors. Some of these used the lift-all or "belly pump" hydraulic reservoir for the live pump. In other cases the reservoir was a separate tank. I've seen some that were part of the loader frame.
Removing the pump may have some hidden surprises, but in some cases (perhaps most) you can simply re-install the distributor once the pump is out of there. The pump didn't really replace another casting, it was just installed between the distributor and the drive shaft.
Post a Followup
: Re: Re: Farmall H front Hydraulic Pump
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
