Farmall Tractors Discussion Board
Re: Super A Hyd. Pump
Posted by steve on April 16, 1999 at 11:34:09:
In Reply to: Super A Hyd. Pump posted by J Risher on April 15, 1999 at 18:50:27:
My Super A does exactly that - so I back off the levers just a hair, which doesn't even make the hydraulics move (so it doesn't affect the implement anyway). I've seen this kind of behavior in other hydraulics, like log splitters - so I'd guess it's normal.
I wouldn't worry about it. Mine did it before and after a fluid replacement and bleeding. Just use the hydraulics in the quiet range, rather than at extremes.
Steve
Post a Followup
: Re: Re: Super A Hyd. Pump
