Re: H Question
Posted by D Slater on March 18, 2009 at 19:39:22 from (72.65.149.238):
In Reply to: H Question posted by farmallboy1994 on March 18, 2009 at 15:07:15:
Some use the type that hook to 5/8 or 3/4 heater hose. Tied into block drain and a tee installed were temp. gauge fitting screws into head. Your 40 H may have exspantion plugs to coolant but there under the front engine cover and rear engine cover.
