Posted by John T on March 18, 2009 at 19:50:40 from (71.52.194.12):
In Reply to: generator posted by josh watson on March 18, 2009 at 17:44:28:
Scotty gave you the link to my long winded but complete test procedure, but heres short answers to your direct questions:
The next question is how can i tell if the gen is outputting simply?
Place a voltmeter on the battery, if its a 6 volt battery it should read around 6.3 volts (twice that if a 12 volt) just setting there tractor not running,,,,,,,,then when she is runnign at fast RPM IFFFFFFFF the charging system is working,,the battery voltage should rise to the 6.5 to 7 or a lil over range (twice that on a 12 volt system) ..If it never increases battery voltage, shes likely NOT charging..
can i read with a ohm meter at the gen?
NO you need a voltmeter
if so which contacts?
The gennys output is measured from its ARM post to case ground
The wiring is new and known to be proper but i dont know if the switch, relay or gen are to blame.
See Para 5 of my Troubleshooting Procedure to see if non charging is a generator versus a regulator or light switch type of a problem.
If you jump the gennys FLD post direct to case ground she ought to max charge so when shes running at fast RPM momentarily short the gennys FLD post to case ground n see if she charges then (ie see if battery voltage rises and/or ammeter shows good + charge). If so but NOT otherwise, the genny is okay so the problems in the light switch or its not grounded or the wires open from FLD on genny up to light switch........ If dead grounding the FLD post dont make her charge, leave it grounded when shes running and temporarily by pass jump around the cutout relay by connectign its BAT terminal over to its ARM/GEN terminal n see if she charges then????? If so but NOT otherwise the cutout realy is bad or not well grounded. If theres still no charge with FLD dead grounded and the cutout relay by pass jumped, sounds like the genny isnt charging
Check my procedure that Scotty posted for more detail
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
