Re: Pump Capacity ? Pressure?
Posted by charles todd on March 18, 2009 at 20:52:51 from (205.242.95.135):
In Reply to: Pump Capacity ? Pressure? posted by Clean John? on March 18, 2009 at 17:29:08:
The relief pressure on the 06 series up through the 86? series is 1600 psi. The filters will burn ya everytime. Replace the filters and check the pressure, it still lacking the relief or a check valve may be by-passing.
Charles
