Farmall Tractors Discussion Board
Re: Re: Re: Re: DIFFERENCE BETWEEN SUPER A AND A-1
Posted by Guy Fay on April 19, 1999 at 04:08:54:
In Reply to: Re: Re: Re: DIFFERENCE BETWEEN SUPER A AND A-1 posted by Don on April 18, 1999 at 18:34:53:
Super A-1 would be only 1954 production- if you've got a 52, it sounds like you've got an industrial, especially when you've got the square axle.
From the production change authorizing production, here's the differences between Super A-1 and Super A.
C-123 engine, instead of C-113
New radiator grill using Super C upper and middle sections with Super A lower section
Super C radiator, hood, fuel pump and connections, fan housing, and air cleaner
Super AV rear axle housings for Super A-1 and International Super A-1
Maximum Capacity rear axle inner bearings
Revised differential case using new side gear and pinion gear thrust washers
New steering gear housing
Other Miscellaneous parts
The only decal that changed (from memory) is the air cleaner decal. There never was a "Super A-1" decal.
Post a Followup
: Re: Re: Re: Re: Re: DIFFERENCE BETWEEN SUPER A AND A-1
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
