Farmall Tractors Discussion Board
Progress report on that Dang Ol 51 H. Getting better.
Posted by The Red on April 19, 1999 at 15:47:13:
Well the governor is working nicely now. Got all the oil leaks around the governor stopped.
Carb wise, I got the high speed leaned properly but cannot turn in the idle screw enough to lean it all the way. However after blowing a bunch of crud out of the carb., it is idling consistenly now and not dying on me.
Tomorrow morning will be raise the liftall, hook it up and see what leaks.
It is not running as smoothly as my 46 Indy H but it isn't too bad. Gotta modify the throttle lever so it will hold in the teeth. Its shot.
Post a Followup
: Re: Progress report on that Dang Ol 51 H. Getting better.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
