Re: Super M Horsepower?
Posted by Bob M on March 19, 2009 at 05:37:23 from (151.190.254.108):
In Reply to: Super M Horsepower? posted by DHad on March 19, 2009 at 04:26:39:
Stock is HP 46.3 per the Neb tractor test #476. 65 HP is possible - however it requires a LOT of engine modification/upgrade.
More likely 65 HP is a simply number the seller pulled out of his posterior. Might even be the same guy who offered a "1943 Super M" here recently. (Upon close inspection the only thing 'Super' about it was the decals on the hood.)
Buyer beware!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
