Farmall Tractors Discussion Board
Re: Carb for SAV
Posted by Curt Cooke on April 21, 1999 at 07:03:46:
In Reply to: Carb for SAV posted by Ken on April 20, 1999 at 20:20:40:
Yes, the other carbs. will work. Before you buy, you might want to check out my post yesterday in response to TISCO rebuild kits. Also, there are really no meaningful parts in a kit beyond the gasket between the two halves and a needle and seat. Bothe the gasket and needle and seat are readily available as far as I know and a new carb. is 250 bucks.
Post a Followup
: Re: Re: Carb for SAV
