Farmall Tractors Discussion Board
Re: Farmall A clutch adjustment
Posted by Skip on April 21, 1999 at 08:08:56:
In Reply to: Farmall A clutch adjustment posted by Ray Matchell on April 21, 1999 at 07:17:46:
Ray, Where are you adjusting the rod? I&T manual says NOT to adjust fingers, the linkage adjustment is lower rear of clutch housing, through an opening
Good Luck
Post a Followup
: Re: Re: Farmall A clutch adjustment
