Farmall Tractors Discussion Board
Re: Pulling Sleeves
Posted by Clint Hofstetter on April 21, 1999 at 11:03:00:
In Reply to: Pulling Sleeves posted by TMAC on April 20, 1999 at 19:23:58:
Sleeve kits are no longer available, however the individual sleeves, pistons, rings, etc. are available from CaseIH dealers. The origional 3 7/8 dia. bore is not available, however you can get 4 in. bore. Gives you a Super MD when you are done in terms of power. Now comes your other requirement to be reasonable. Be prepared to spend some big bucks, especially if you need to do main bearings, rod bearings, valves, cam shaft bearings, etc. These are also available, but you may decide not at a reasonable price. This is a very expensive engine to overhaul! Good luck, e-mail me if you have any other questions, my son is in the process now. Our local NAPA machine shop has been invaluable as has our local CaseIH dealer.
Post a Followup
: Re: Re: Pulling Sleeves
