Farmall Tractors Discussion Board |
Re: Need a 3 bore sleeve
Posted by Stan(VA). on April 21, 1999 at 18:07:26:
In Reply to: Need a 3 bore sleeve posted by Brian on April 21, 1999 at 09:24:59:
Is your 3" diameter for the piston or the outside of the sleeve? If for the piston, the Farmall A,B,C motors came with a 3" piston. The outside sleeve diameter down at the o-ring seal was 3 5/16", or 3 7/16" for the Super C block with the 3 1/8" piston. Stan(VA).
Post a Followup
