Re: Head and manifold on!
Posted by spiffy1 on March 19, 2009 at 09:46:06 from (70.41.137.72):
In Reply to: Head and manifold on! posted by Bob in Mi. on March 17, 2009 at 22:51:41:
Now I can't believe some of the purists didn't note that the lower selector should have been secured by a fine thread castellated [IIRC] nut instead of a coarse thread brass nut.
However, since the tractor will be a "functional combination" of factory correct and owner's nostalgia [it was last used in the early 80's - original: manifold/carb/mag; updated with: variable governor/slide rod throttle linkage/straps instead of curtains/rubber tires] correct:
I used the fact that I had couple extra 1/2-13 nuts, and the 1/2-13 in the die-stock as an excuse for a bit of artistic license.
