Farmall Tractors Discussion Board |
Re: Re: Rear end noise in Farmall H and M
Posted by john d. on April 22, 1999 at 12:08:16:
In Reply to: Re: Rear end noise in Farmall H and M posted by The Red on April 22, 1999 at 10:20:38:
Red's likely on the right trail, Bruce. Try jacking up one rear wheel and turning it slowly with the engine OFF and transmission in NEUTRAL. This may let you determine which side of the tractor has the problem. It's also possible to get some strange noises out of a brake. If you have to replace those big carrier bearings for the axle on an M that's working hard, you can use 560 bearings which are considerably more durable. I don't know if there is a comparable swap for an H using 460 stuff.
Post a Followup
