Farmall Tractors Discussion Board
Re: Farmall 200 / identification/////help!
Posted by Stan(VA) Its a '55 model. on April 22, 1999 at 13:43:58:
In Reply to: Farmall 200 / identification/////help! posted by Bear on April 22, 1999 at 13:26:46:
Plate on the bellhousing is the tractor serial number, it shows you have a '55 model. The engine number is stamped on the block just above the distributor mount, but you probably woln't need it. Should be a 123 cu in, 3 1/8" bore, wet replaceable sleeves. Overbore piston/sleeve sets with 3 1/4" bore are available also and more commonly used. Valve train, gasket sets, and bearings are all readily available.
Stan(VA).
Post a Followup
: Re: Re: Farmall 200 / identification/////help!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
