Farmall Tractors Discussion Board |
Re: Farmall 200 / identification/////help!
Posted by Stan(VA) Its a '55 model. on April 22, 1999 at 13:44:12:
In Reply to: Farmall 200 / identification/////help! posted by Bear on April 22, 1999 at 13:26:46:
Plate on the bellhousing is the tractor serial number, it shows you have a '55 model. The engine number is stamped on the block just above the distributor mount, but you probably woln't need it. Should be a 123 cu in, 3 1/8" bore, wet replaceable sleeves. Overbore piston/sleeve sets with 3 1/4" bore are available also and more commonly used. Valve train, gasket sets, and bearings are all readily available. Stan(VA).
Post a Followup
