Re: M Farmall Info
Posted by r4etired on February 18, 2007 at 18:17:02 from (152.163.100.199):
In Reply to: M Farmall Info posted by Bigramjack on February 17, 2007 at 16:17:06:
If it has a cable operator it is a Behlen. the cable enters the trans thru the second bolt down on the right side.about 1/3 way thru the trans, the cable connects to a linkage arm that pivots on a special pin that replaces the pin holding the reverse counter shaft in place. Where the cable enters the trans there is a small compression nut. It threads on the outside of the cable, the bolt is tapt for the outside of the nut,This locks the cable in place and seals from oil leakage The pulley drive gear is replaced with a double gear, one original one with about 15 more teeth, the inside of these gears have .8 square dog drive,two pins run thru the gears for shiftlng Heisler also made a 9 speed,it has hard linkage into the left side, MandW used hard linkage on the right side, With standard rear tires they all gave speeds of 7 9 12 15 mph
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
