Re: A wont start unless you put gas in the plug ho
Posted by IH2444 on February 19, 2007 at 07:49:30 from (192.76.82.90):
In Reply to: Re: A wont start unless you put gas in the plug ho posted by Chad from Michigan on February 19, 2007 at 06:39:35:
The idea above about checking the intake suction is a good one. If it is good then the problem is most likely in the carb. Leaky float valve would be a common problem. Or perhaps a clogged jet, or both...
