Re: 248 Block Bore
Posted by El Toro on February 20, 2007 at 04:21:34 from (205.188.116.133):
In Reply to: Re: 248 Block Bore posted by Lawmar on February 19, 2007 at 17:33:23:
You can put an over bore sleeve kit in that block
to boost the bore to 4.00" without any machining. I think those sleeve walls would be thicker than 1/32". Call Federal Mogul to be sure. This is the block bore that I'm referring to. Hal
