Re: Disconnecting bucket on FEL for IH3514
Posted by JayWalt on February 20, 2007 at 05:28:48 from (70.226.20.153):
In Reply to: Disconnecting bucket on FEL for IH3514 posted by adefreit on February 19, 2007 at 17:57:41:
well since nobody seems to be taking a stab at this, I will. I dont know anything about your tractor. However, there is a few things to follow. When removing the bucket make sure it is flat on the ground. Make sure the valves are in neutral. and make sure the engine is off. With the engine off and the valves in neatral and the bucket flat on the ground, there should be no pressure on the hydraulics. If your lift arms have downpressure, do not force the bucket down with them, just rest is a hair on the ground.
What kinda of mounts does the bucket have?
If you are somehow referring to a grapple or auxillary hydraulic bucket and are concerned about the hoses, if they have on them what appears to be big air hose fittings, these are quick connect fittings and come apart just like an air hose, and if they are in acceptable shape they wont leak disconnected. Be sure to cover the fitting when disconnected so they dont get dirt in them and eventually in the hydraulic system.
