Re: 350 Hydralic pump problem
Posted by r4etired on February 20, 2007 at 05:46:52 from (205.188.116.133):
In Reply to: 350 Hydralic pump problem posted by Gordy from Iowa on February 20, 2007 at 04:49:07:
In the early 60's I had a super H that had the same problem, Replaced the seals with IH seals twice I took the shaft to a bearing company to find the shaft was metric, used metric seals and cured the problem,Might not be your problem but I would check it out
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
