Re: 350 Hydralic pump problem
Posted by Janicholson on February 20, 2007 at 06:11:13 from (199.17.6.122):
In Reply to: 350 Hydralic pump problem posted by Gordy from Iowa on February 20, 2007 at 04:49:07:
Shaft wear can be a problem in two areas. One is the seal lip location, if it is worn (grooved) it will continue to leak. If the pump bearings are worn, (and the housing is still good without gear wear on the sides of the housing) it could be rebushed (still pretty expensive), or a different pump will be needed.
A worn groove can be repaired with a speedy sleeve over the groove, and a seal to match the new diameter. Good luck JimN
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
