Re: Mounted plow for an H
Posted by NDS on February 20, 2007 at 16:18:36 from (64.12.116.71):
In Reply to: Mounted plow for an H posted by grantl on February 20, 2007 at 15:58:54:
Saw several around when Hs were being used for full time farming. The plows did a good job but switching from plow to disk etc. was a big job so most people I knew went to trailer plows just pull pin from clivis untie trip rope and drive off.
