Re: Super C Swinging Drawbar Pivot Pin for Fast Hi
Posted by farmallhal on February 21, 2007 at 06:56:21 from (64.85.221.96):
In Reply to: Re: Super C Swinging Drawbar Pivot Pin for Fast Hi posted by Hugh Mackay on February 20, 2007 at 17:49:06:
Hugh, I measured the hole in the drawbar and it is a little shy of 15/16". I'm thinking the pin is probably 7/8" (.875 in.) to allow for clearance. From the shoulder under the head the length would have to be 4 1/2" - 5" as the quick attachable cotter pin hole would have to be between the bottom of the hitch and the end of the pin. The bolt goes through the attaching point on the tractor at an angle and is not straight up and down. The axis of the pin is probably off the vertical at something around 10 or 15 degrees. Don't know if the cotter pin hole would be parallel to bottom surface of the drawbar or perdendicular to the shaft of the pin. I've never seen the correct pin before so don't know any of it's characteristics. Thanks for your response, Hal.
