Re: 'Nother dumb hydraulic question
Posted by Nat 2 on February 21, 2007 at 11:19:11 from (64.80.108.53):
In Reply to: 'Nother dumb hydraulic question posted by SF Mike on February 20, 2007 at 19:26:20:
Your description is a little vague. Are you saying that the lines to the 3 point come directly from the "belly pump," the sides of the big casting between the back of the engine and the rear end? Okay, assuming that, the belly pump, or hydraulic Liftall as it was called, has two OUT ports on the left, and one on the right. The front left port and the right port apply pressure at the same time. The rear left port has a delay before it starts applying pressure. If two hoses from the same cylinder go to the two ports on the left, that is BAD. You will blow up the Liftall if you attempt to use it this way, worst case. Best case it will not work well at all. The correct plumbing is: 1. Bottom port on left cylinder to front left liftall port. 2. Bottom port on right cylinder to right liftall port. 3. Top port on BOTH cylinders to a T-fitting. 4. T-fitting to the drain on the bottom of the belly pump. Lower the 3 point all the way, then refill the belly pump to the point indicated on the dipstick. This gives you gravity down and power up. You are also using the 3 point cylinders are external reservoirs. If you want power up, power down: 1. Bottom cylinder ports to a T fitting. 2. Top cylinder ports to a Tee fitting. 3. T-fittings to "work" ports on an open-center two-way valve. 4. Right liftall port to the IN port on the two-way valve. 5. OUT port on the two-way valve to the a Tee fitting installed on the filler neck of the liftall pump under the gas tank. 6. Plug the vent hole in the filler cap, or replace with a standard 3/4" pipe end cap.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
