Re: farmall h stuck in gear
Posted by Janicholson on February 21, 2007 at 16:31:06 from (66.173.50.139):
In Reply to: farmall h stuck in gear posted by dm on February 21, 2007 at 13:14:42:
There are usually two small plugs in the shifter tower system that need to come out (at least one) the pin under that is driven out the other side, and the lever comes out. Align the rails (the one on the left rear will be pushed back) use a screw driver to pull it forward to align with the others. Pushing in the clutch will/may help. The tip has been pictured in this forum many times, it is kinda the shape od a chicklet chewing gum (before chewing). It can be welded up some on the bottom corners, then ground down to fit nice, and shift well into all gears without binding (this takes patience, and several fitting sessions) It is not a size thing to measure, it is sized to match what is worn on the rails. If the plugs fall out, put some #1 hardening permatex on them to hold them in place. I hope this helps. JimN
