Re: Farmall H Applied Physics
Posted by CNKS on February 21, 2007 at 17:15:23 from (204.249.178.32):
In Reply to: Farmall H Applied Physics posted by City-Boy McCoy on February 21, 2007 at 15:44:38:
Not trying to be sarcastic, but if you can't feel the tractor "in the seat of your pants", nothing you do will prevent a roll over. If you think you are in a dangerous situation, you are. No amount of added weight is going to prevent that from happening. Stay away from slopes you consider dangerous. I doubt if the mower on the ground would make any difference. The only safe tractor in that situation is a low profile/center of gravity utility tractor with the wheels as wide as you can get them.
