Re: Will M - crankshaft fit in a 400
Posted by Owen Aaland on February 22, 2007 at 00:42:33 from (65.165.246.11):
In Reply to: Will M - crankshaft fit in a 400 posted by SDE on February 21, 2007 at 15:19:31:
If the shaft is too far gone to be turned for 400 bearings you may be able to get it reground to M specs and then use M bearings. You may even get by with standard M bearings.
