Re: Exhaust pipe removal. How difficult?
Posted by El Toro on February 22, 2007 at 10:24:50 from (152.163.100.199):
In Reply to: Exhaust pipe removal. How difficult? posted by Mike CA on February 22, 2007 at 09:04:36:
I would use an acetylene/oxygen torch to heat the heat the area. If you don't have this take it your local muffler shop. They run into this problem quite often and they do use the torch. You can't beat the heat. If the threads need to be chased you can rent the correct size pipe tap.
They may even have them on your Navy Base at your Post Engineer's branch or division that does the
the base plumbing. Since I'm retired from the US Government I know all the military bases have this. They would probably do the thread chasing for you. Hal
PS: Home projects usually got first priority.
