Re: tractor vet?
Posted by RustyFarmall on February 23, 2007 at 07:05:54 from (66.43.253.11):
In Reply to: tractor vet? posted by whtpark01 on February 23, 2007 at 06:53:21:
There is a packing gland located inside the carb where the solenoid installs. It is not likely that this packing has failed, but it is possible. You might try tightening the packing nut, but don't get too overzealous with it. If that doesn't work, you will need to replace the packing.
