Re: Timing a IH 140 - best method
Posted by Ih2444 on February 23, 2007 at 09:10:06 from (192.76.82.90):
In Reply to: Timing a IH 140 - best method posted by Nawlens Gator on February 23, 2007 at 08:38:22:
I recommend using a timing light. Use chalk, paint or something to brighten up the timing mark.
Yes bad engine timing can cause overheat, valve and even piston damage.
