Re: Timing a IH 140 - best method
Posted by El Toro on February 23, 2007 at 09:14:03 from (205.188.116.133):
In Reply to: Timing a IH 140 - best method posted by Nawlens Gator on February 23, 2007 at 08:38:22:
If you can locate the timing marks on the flywheel
I would chalk that timing line and then use a timing light to set the timing. It will take a helper so you can do this. I use an inductive
timing light from Sears. Hal
