Re: farmall c
Posted by gene bender on March 19, 2009 at 13:25:58 from (67.55.226.247):
In Reply to: farmall c posted by d farms on March 19, 2009 at 12:36:12:
If they rebuilt it the input lever syould no wobble aroun. With engine off remove the clevis going to the carb. Now open hand throttle all the way. Now the pin in the clevis should fall in whenpushing the rod going to the carb. You mite need to remove that rod and free the clevis so it turns easy. The lever out of gov housing on carb side is spring loaded check it out when the linkage is unhooked. Let us hear how you come out.
